Topic: Mk7 door panels on 87-8 Tbird? (Read 1893 times) previous topic - next topic
Did a search and either I missed it or not much has been done on this?  Anyone?
http://www.coolcats.net/library/parts.html -
"Mark VII panels can technically fit but will result in squeaking where the panel meets the dashboard, as well as less-than-perfect fitment."
CoogarXR : 1985 Cougar XR-7
That came from personal experience, too. I like them, nice panels, actually less complex and a little more streamlined than a lot of the Cougar/T-Bird panels. But you'll never not get them to squeak. Only other options would be to do some surgery on the panel by the dash area, which probably will create less than desirable results, but they can be recovered to look halfway decent. Or, swap out the dash to a Mark VII.
Did you try both styles?  '84 - '89 and '90 -'92 are shaped different at the front due to the dash redesign.
1990 Mark VII LSC
1990 Mark VII LSC SE
1969 Cougar 351W
