Topic: 1986 3 speed (Read 6772 times) previous topic - next topic
1986 3 speed
Column to flor swap any one ever tried it and is there a way to keep the indacater working
1986 3 speed
Either a 6 or a 4, the 8's, (at least aero ones) always had the 4 speed, boxy ones might have had V8 & 3 speed, I don't know off hand.
I'd look for the shifter assembly from an 84-86 turbo 4 car.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
1986 3 speed
Column to floor shift has been done many times. The three and four speed automatics use the same shifter (except the turbo 4-speed, that one uses its own unique one). To do it factory style you'll need the shifter, cable, associated hardware, and you'll need to modify the linkage on the transmission to retain the stock PRNDL pattern. If your car has the consolette (center console moves with the seat) you'll also need the console, center dash panel, ashtray block-off plate (or cig lighter panel), and appropriate shifter bezel. You'll also have to modify the driver's seat, as that consolette is welded on. The parts to do this swap may be hard to come by, and frankly you really don't gain anything from it. You'd probably be better off putting a cupholder/tray thingy there.
An aftermarket shifter from B&M or the like might be a better option...
1986 3 speed
V6 and not going to stick with factory
1986 3 speed
And that was a mess up
1986 3 speed
All 5.0 from 83 and up have the AOD, i believe all the 80-82 as well, maybe optional for 82 on the carbed 3.8...but not sure.
Travis
1986 3 speed
Nope, aod is od-d-1. Aod was optional in the 3.8 until 1986. A4ld was the only 4 dent shifter.
1986 3 speed
Oops, your right. I misread your post.
1986 3 speed
The C5 had a locking torque converter, which was ALMOST like having OD.
1986 3 speed
Looking at b&m but they all say c4&c6 no c5
1986 3 speed
I was looking at these awhile back,would something like this work ?
http://www.summitracing.com/parts/lok-ats60c4bm/overview/
1986 3 speed
It's for a c4 but looks nice  I have found a thread or 2 that say thay will fit a c5 and that c4 & the c5 are about the same
1986 3 speed
Looking further in to it before I start buying
