Topic: 2.3 turbo engine gurus step inside.... (Read 8087 times) previous topic - next topic
Thats shot
Yup
Lol that thing is nasty
I have never seen an intake water port eat up like that on an aluminum intake.....on a v8.....
what the world? posts missing........
straight water with no antifreeze or corrosion inhibitor?  This is a southern car, right?
Quote from: razzys wagon;444682
I think somebody is no longer welcome here (probably banned...)
Is southern, I had coolant in it.....don't know what it sat 10 years with.....
And I gathered someone was kicking sand.....sorta...
ok, so its safe to reuse the 6 point head bolts then?
No, only the factory 12pt head bolts are
I thought the 12 point ones were tty .......  Guess I'm backwards, as usual!!!!    Lol
ok, new problems, I got it running and of course it needs a tune from all the changes, but, im driving it about a week-week and a half.....it does the pop back in the intake and cuts off, still coasting and the tack is on 0. that had me puzzled to begin with. took the dizzy out and the teeth were chewed off....never messed with the aux shaft or dizzy while it was down other than the timing belt.
now I replaced the OEM dizzy with another OEM dizzy from a mustang and it ran fine now for another 2 weeks. looked at the aux shaft while it was out and the gear look fine. well, the same thing happened this morning so now.........im getting another OEM aux shaft next week and then investigating the whole situation.......
anyone ever have this problem before? any tips you can throw my way on this issue? anything at all!!!!!
thanks guys...
