Topic: Whats used to plug smog hole on 88 heads (Read 1788 times) previous topic - next topic
Well, we removed the smog tube and hardware for our build and just wondered what's being used to plug the holes up. Mine happens to have 2, one in each head at the rear edges. Looks like a small ovalish plate with a hole drill for lock down bolt and maybe throw in the gaskets that were supplied in the gasket kit to make the seal.
Maybe a bolt with a head thread tapping? What size tap would be best to use? Would a brass plug or stainless steel be best?
Thanks
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
http://www.latemodelrestoration.com/item/LRS-6086AK/1979-95-Mustang-Cylinder-Head-Smog-Plugs-for-50L-58L?utm_source=google-shopping&utm_medium=comparison-shopping&utm_campaign=google-shopping-v2&gclid=Cj0KEQiA6dGmBRC_3Mi-x_XywKsBEiQA1lcFP9R9zHXIl4HjI0LfRlXAkBSQz6020TLTarIRYa9FgVIaAmY48P8HAQ
You're welcome. :)
As for the size of whatever you'd need...no idea.
On my HO that was in the Tbird I had, I simply cut off the heads of two carriage bolts, stuck them into the thermactor holes, took the crossover pipe and cut each end off, globbed the hole on each piece with a big dose of permatex, and then bolted the pieces down in the proper place. Redneck as hell, but it worked for me. Not like it was a show engine..just a worn out, 150K mile HO that smokes on starts and when you lift off the gas. Needs rebuilt, so I wasn't spending much on it. ;)
cheap. take the crossover tubes off cut them apart and flip the ends over re install.
That too.
The threads specs: Outer threads measure 5/8x11
Later heads just had a 5/8" coarse threaded hole.  So tapping and threading them to that size should work fine, along with some short 5/8" bolts with a bit of exhaust sealer smeared on.
cheers
Ed
84 Mustang SVO
95 Jaguar XJR
Awesome guys, thanks for the help. Luv them descriptions, lol.
1988 Thunderbird V6
