Topic: Wiring msd 6a and coil to TC help. (Read 1377 times) previous topic - next topic
Hey guys can you help me out wire a msd 6a box and blaster 2 coil to my TurboCoupe? I know that the coil gets connected to the box and I need to find a wire with the ignition but do I connect the wires that go to the dissy? Also what harness do i need to make the stock tach work thanks guys lmk if I missed anything. thanks
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Re: Wiring msd 6a and coil to TC help.
Also guys while I order the harness i need to make the tach work how do I wire the coil alone, using the same wires the stock coil is using? thanks guys lmk
are you still running EFI with the TFI distributor?
this coil is not a good choice..
if your still useing the stock style EFI setup you need this coil..
here is the links you need
http://www.msdignition.com/downld1.htm
http://www.msdignition.com/pdf/6%20series/6series.pdf
oh and if you wire the MSD they way they tell you. the factory tach will work.. with no modifcations at all
Nick
