Topic: WTB 1986 Thunderbird Dash Cover (Read 1098 times) previous topic - next topic
Hey guys,
Does anybody happen to have the whole plastic dash cover (not the gauge cluster but the whol plastic element that goes over it, vents, radio, etc).
Condition needed:
Great condition with no cracks. Needs to have all the mounting tabs and holes.
Needs to be the style that is black around the outside and the entire "faceplate" be that brushed aluminum look.
Needs to be for a 86 ford thundernird base model. (It housed the digital cluster in a v6 if that makes a difference)
Dont message me on here. Please use the provided e-mail.
efleury10@hotmail.com
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
https://www.dashcaps.com/xcart/product.php?productid=16977&cat=318&page=1
http://www.dashtop.com/products/dash-cover-1985-1988-ford-thunderbird-mercury-cougar-xr-7
I THINK I ordered from the first link when I did mine.  That was about 7 years ago....
If you have any cracked areas on your original that have pooped upwards or out, cut them out before installing.  If you install these correctly, it's near impossible to tell you have one.
Last time I saw a full original dash for sale was on ebay.  It's one piece and incorporated into the framework for the dashboard meaning it doesn't just pop off.  It was pristine, but $500....
Thanks for the links, but I meant the whole "bezel" type cover that goes over the front. Surrounds the Guage panel and such. Ill try to post a pic when I can.
