Topic: Gray smoke.... (Read 8061 times) previous topic - next topic
Gray smoke....
I agree Kitz. Ihoep to do that this summer. Yeah, that's a few months away, but, it is what it is.
Gray smoke....
Kitz, other than the smoke, it's doing pretty good. Not 100%, but pretty good. It'll get there. I have no doubt about that.
Gray smoke....
valve stem seals?
Gray smoke....
Vinnie is swapping a Tmoss ported GT40 lower on soon, which is why I suggested checking the intake manifold gaskets for leaks. If he wasn't swapping intakes I wouldn't have suggested it.
Gray smoke....
I know its frustrating, Just hang in there Vinn.  Just putting some good mojo your way.
Mike
Gray smoke....
Thanks guys. Cold and raining today on my day off....of course. LOL. No worries, the ported lower is going to be here Monday. I hope to get into it next weekend. If not, well.... as soon as I can. The smoke didn't start until the head and cam swap. Crazy. I think I might go ahead and pull the heads, swap gaskets and valve seals (whether they are needed or not), Can't hurt, then see what happens. It doesn't make sense that it started when those parts were swapped unless it's a gasket issue or a seal issue. Hmmmm.......I gotta think on this a bit.
Gray smoke....
If the heads were brand new when you installed them then I doubt the valve seals are bad.
Gray smoke....
Quote from: vinnietbird;443736
Tell us about the heads...all new parts, or used stuff that's been freshened up? Valve job? new seals?
Gray smoke....
Brand new afr 185's, I sold them to him.
Gray smoke....
Reply #39
what are the stats on the bottom end vinnie? Could be a little blowby or sticky oil rings? just a little seeping past the rings? sucking oil through pcv?
Gray smoke....
Reply #40
Yep, sucking some oil through the PCV. I have another XXX short block in the garage I'm gathering parts for slowly.
