Topic: Mech fuel pump (Read 1137 times) previous topic - next topic
Mech fuel pump
I got an 84 ho in the garage that I want to put in my ranger. I want to run a carbed setup and I was curious about what all was involved in putting a mechanical fuel pump on it. Truck was already carbed and I dont feel like running wires and all that good stuff for an inline pump.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Re: Mech fuel pump
change the timing cover to a cover that will allow you to bolt on a fuel pump plus the wheel on the cam gear and away you go :D I did this on the 85 302 I put in my 79 cougar runs fine
Re: Mech fuel pump
the cam is probably going to have the pump lobe/wheel already molded on it.
ive often wondered since the timing cover bolt holes are already threaded,, why not just cut out the hole for the pump arm?
Re: Mech fuel pump
Hmm. Might try that. I know theres a hole right where the pump would go, whether or not goes the whole way or not I don't know. I'll just pull the cover off later and check it all out. All I got to do now is find a cheap 2-bbl carb until I can find a new intake.
85 Tbird 5.0
78 F150 351w
