Topic: Might be getting an 87 TC (Read 4530 times) previous topic - next topic
Silver with Raven interior, 5 speed, 96k miles, lot of work done to it, some rust but no worse than my 86, Low optioned too. He wants to trade for my 87 Ranger, I said I'd throw in the 86 Tbird too, lol
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Go on the Milwaukee CL page, it's located in Oconomowoc.
Here ya go
X
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
I went and looked at it yesterday, it's a little rough, but ran ok, brake & abs lights were on, windows, clock, radio, and wipers didn't work. brake pedal was really hard, and the Firm light came on whenever i hit the brakes.
Quote from: White85GS;443298
That could be a nice find...... could be as simple as some blown fuses, as thats a lot of non working stuff all at once.  Look at the main vaccum line by the firewall, if it popped off you will have to stand on the brakes as the booster isn't getting vacuum.  Happened to me 3 months ago on my Cougar.  BTW is the thumb included with the car?  :-)
This has ABS, no vacuum style booster, just like your Mark VII. Lol, I hate when ppl cover up their plates.
The hard pedal is due to a failed brake accumulator ball. That why the brake light is on. Spinning wheels sc has new ones available. I have a huge collection of good used ones.
http://spinningwheels-sc.com
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
, $135 for the accumulator
If ya get the car let me know. I'll cut ya a deal on one. Just be sure to install a new o-ring on the base. It's a -111 o ring
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
As much as I'd love an intercooled Turbo Coupe, I think I'm going to pass on it, they are just way too complex.
Idk, guys, should I still pass on it?
The windows, clock, radio, wipers etc are probably all related to one thing. My guess would be a bad ignition switch or ignition switch connector (or both), or a burned or broken fusible link out by the battery.
An '87 TC doesn't really have anything more complex than a base 87-88 Bird, except for the ride control and ABS. Parts for the ABS system are readily available, as jandmmustangs said, and the PRC system is usually pretty reliable except for the fact that you can't buy new PRC struts anymore. If the body of the car is decent (CHECK THE FRONT FRAME RAILS!!!!) and it runs decent and builds boost without tailpipe smoke, it's probably worth snagging. Remember, opportunities with these cars are getting rarer...
the positive cable to the battery was pretty beat up, that could affect a bunch of stuff?
Well if both the red brake light and the yellow ABS light are on you've got problems. More than likely the accumulator died. Then it was run with a dead accumulator for quite some time which killed the pump (running on every brake application). So now it probably needs a $900 rebuilt master cylinder/brake booster assembly. Screw that. Convert to vacuum brakes. I'm more than likely going to do that to my Mark VII. The Teves II system is a very stupid design vs the later ABS systems.
