Topic: Is this normal? (Read 3435 times) previous topic - next topic
Is this normal?
I was driving the '85 yesterday and I had to turn around at an intersection (gravel side roads/blacktop highway). When I turned left on the loose gravel the front wheels kept skidding forward like a 4wd truck trying to turn when locked in 4wd. It only does it when the wheels are turned all the way to the left and not even going very fast.
Is this just a thing with early rack and pinion steering?
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Is this normal?
Sounds like u got a  good limited slip rear. Completly normal
Is this normal?
Normal for many rear drive cars to "plow" a bit when turning sharply at low speeds on gravel roads.  Front drive cars don't have the same issues since the front wheels are pulling you through the turn (as opposed to rear drive cars pushing through a turn).
Is this normal?
Tap of the gas solves it. Well, maybe not on a 3.8...
Is this normal?
Ok, cool. I'm sure glad it's nothing I need to be concerned about.
Cornfed85
Is this normal?
If it only does it when turning one direction versus the other you may want to take it to a tire shop that can check the front end alignment. It almost sounds like something is out of whack if that is the case.
Darren
Is this normal?
I just had it aligned a month ago. They supposedly checked everything. I have noticed that sometimes there is a clunk/pop noise coming from the front end when turning sharply or where the steering/suspension has to flex. Not entirely sure what's causing that either.
Cornfed85
Is this normal?
Surely with only 80,000 miles, the suspension should still be good, wouldn't it?
Cornfed85
Is this normal?
ASS|U|ME things and you know what that gets you.  I would take it to another shop and see if they can figure out what it popping.  They need to check the control arm bushings, ball joints, rack & pinion, rack & pinion mounting bushings, inner & outer tie rod ends, sway bar bushings, and the strut bushings that are bolted to the top of the shock tower.
Darren
Is this normal?
80,000 miles but also 30 years. Rubber goes bad from sitting as well as mileage use. 30 years is old for stock bushings, no matter the mileage.
Is this normal?
Well, I need to do some brake work. Is there a good way to check the all things you listed? I can do a lot of the testing of parts while it's up with the wheels off.
Cornfed85
Is this normal?
A Google search on checking tie rods, ball joints, rack & pinion, and control arm bushings would be the quickest way to get some idea of how to do this in your driveway or garage as its just too much to type. You could also do a search here or on one of the major Fox Mustang sites.
Darren
