Topic: Want to buy A9P Mustang computer for MAF conversion (Read 1153 times) previous topic - next topic
Looking for an A9P computer from a Mustang with MAF.  Doing a MAF conversion on my Thunderbird.  Let me know what you got!
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
I actually have everything but the harness and computer itself.
'88 Thunderbird LX
Did you post up in the Marketplace for this?  Also, check the Mustang sites as that is where you will have a better shot at locating one.
Darren
I have a A9P but you must buy the chip, calibrated MAF and 24lb injectors with it. They all work together. I will make you a screaming deal since I do not need it any longer and you are a fourm member and fellow T-Bird lover. I even have the factory bracket, bolts and elbow.
Quote from: Lightningbird;442071
PM sent
'88 Thunderbird LX
Want to buy A9P mustang computer
I want to buy an A9P mustang computer.  Doing a MAF conversion on my Thunderbird.  Lemme know what you got!  Also need the harness.
'88 Thunderbird LX
For the MAF harness plug just go to the junkyard and take the MAF plug and as much wiring as you can from any 88-95 MAF equipped Ford. They all use the same plug. Then go into the EEC-IV plug at the computer and remove four pins from the harness. This is the same thing as the MAF conversion harness that most vendors sell. I did this when I converted my Thunderbird to MAF seven years ago. It cost me less than $15 for the plug and EEC-IV pins at the junkyard. Quite a bit of savings over the $50+ that most vendors sell the harness for.
