Topic: low end power disappeared? (Read 26574 times) previous topic - next topic
Well I finally finished my SO to HO conversion.  Explorer intake, TW heads, HO cam, 19# injectors and a DA1 (in a pear tree).    The engine runs and has much more power at high rpms but it's very soggy at low rpms.  Even hesitates a little bit. I can't spin the tires from a stop.
Too much air or too little?  I still have the SO fuel pump but I would think that fuel starvation wouldn't happen at low rpms.    One interesting thing is that prior to my conversion, I ran with the IAC disconnected because it would throw itself into a high idle at random times even when warm.  Without the IAC it worked perfectly (except when cold, I had to keep it going).  Now it surges a little at idle and if I unplug the IAC, it dies immediately.
Any ideas?  Thanks in advance.
Look for a vacuum leak.  Swap in a 155 LPH pump.  Do a KOEO, KOER, and CM check.
Nope, but I will now :-)  I'll let you know if that improves things.  Thanks!
Sounds like a timing issue.
Haystack,
Can you elaborate more on the timing issue? My first guess would be you are referring to the cam and timing chain but wanted to make sure that is what you meant.
Darren
A couple free things to check:
1) run codes
2) see if the EEC is advancing the timing by using a timing light and revving up the engine
3) check your fuel pressure at idle with the vacuum hose connected and disconnected
4) look for vacuum leaks as previously mentioned
From there I would suspect your can timing as Haystack pointed out. Did you degree the cam?
Darren
Did you remove the distributor when doing the swap?
Quote from: Aerocoupe;441891
1) run codes
Darren
FYI-
Spark Timing Check
KOER test locks the timing at the base plus 20° (±3°) during the test, plus for two minutes after the last code is outputted.
I did remove the distributor, replace the timing gear with a double and of course changed the cam to an HO cam.  Is there a write up on how to do the KOER test?  thank you for all of the suggestions.
Quote from: V8Demon;441868
+1 and check base timing.
If you don't have a timing light get one or borrow one.
Quote from: marianadeeps;441898
You DID reroute the ignition wires to the H.O. firing order, correct?
As far as checking for any codes:  http://sbftech.com/index.php/topic,2471.0.html
Quote from: V8Demon;441904
Yes I did.  I've now done the TPS/idle adjustment and it no longer surges, and the IAC is working properly.  Now I'm thinking that I just don't have the low end torque I used to have.  My power band is way up in the 3000 rpm and above.  Should I advance the timing?  Trade in my x-pipe for an h-pipe?  Install a higher stall torque converter?  I'm hoping to find a relatively inexpensive solution.  Has any had this issue with their engine upgrade?
I'd say you need to whip out the timing light.. ;)
Did you degree the cam when you installed it? If not did you at least follow the timing chain manufacturer's instructions and install the cam straight up? We need to know this to help you with any further mechanical advise.  Any further mechanical advise would also be pending you pulling any codes both KOEO and KOER.
Darren
