Topic: FS: 1986 TC Shell, buttstuffog Speedos, trunk emblems (Read 2007 times) previous topic - next topic
I have here a couple things for sale:
First up is a 1986 turbo coupe with no engine
The 5-speed tranny is included but not in the car
I did have the car running when the engine was in the car and its a nice solid car, suspension felt like it was in great condition throughout
Brakes and all electrical also works great
Interior is in awesome condition, only thing missing is the pass side door panel but I do have it
Body is in great condition
There is minor rust on the bottom edge of the trunk only
I do not want to junk this car since its in such nice condition but I need to get it out of here
Give me a decent offer and its yours
Car is located here in Central California
Up next is a pair of buttstuffog clusters
 The first one is the one off my daily driver (1987 turbo coupe) and works flawlessly
 Almost 196xxx miles on the odometer but all gauges work great nonetheless
 This is a drop in for a turbo coupe since its factory calibrated for a turbo 4 cyl car
 $50 shipped
 The second one is also off a 1987 turbo coupe and works great
 Almost 167xxx miles on this unit
 The twist on this one is the tachometer is calibrated for a 8 cyl car
 Tach was pulled from a 1988 5.0 t-bird which was originally from a 85-86 turbo coupe hence the boost guage
 I tested this on my turbo coupe and it read exacly half of what my real RPMs were
 So this unit is a drop in for a 8 cyl car
 The clear cover has seen better days (easily swappable) but the cluster itself is in great shape
 $50 shipped
And last but not least are these sets of trunk emblems
 These will be sold as sets (1 "Turbo Coupe" and 1 "Thunderbird" emblem)
 The first set (bottom set) is in pretty good condition
 I have not and will not attempt to remove the original adhesive on the back of the emblems, not that its hard or anything
 $30 shipped
 The second set (upper set) is in even better condition than the lower set
 Same deal with the adhesive
 $35 shipped
 I also have a NOS Turbo coupe emblem that I was going to use but I might end up using my original stuff
 $50 shipped on this one, If it doesn't sell its ok I'll just keep it
PM sent
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
hi, can you post pic of dash n seats ? ....also needing other interior pcs.
You aren't parting it are you?
PM sent
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
No I'm not, sorry supmarjo but the car is pending to 1badbird
Deal fell through and the car is still available
No parts have been pulled yet
Are you parting the car or when you say parts haven't been pulled is that the loose parts for sale
88 tc red, 5 speed daily driver/work in progress.
01 f150 4" lift, 35" tall mud tires, (needs a bigger lift)
88 tc black. New leather interior, motor is a work in progress.
The parts listed are separate from the car, no parts have been pulled yet
I'd like to sell the car as a whole if possible
Well if you decide to part the car let me know.
Which parts are you interested in?
I would be interested in the tail lights if you decide to part it out.  But I would still try to hold out for whole car sale.  That is a nice ride.  Your just too far away from me.
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
Yes it is definitely a nice ride but there's no way I could get it driving at this time
I've posted it on the local craigslist
Hopefully somebody that loves these cars will snag it up
If I don't get any bites I will definitely part it out
Understandable.  I'll keep watching.
