Topic: 87 "coug" resto winter project (Read 121161 times) previous topic - next topic
Reply #180
I had dreams of building a encloser for a computer into that space infront of the wheel wells when i was 16.
How do the trim panels fit around your new brackets? This is something i might just have to do on my cougar.
Reply #181
I didn't show that part yet,, ooppssss.....................stay tuned.
we may have just hosed up!
Reply #182
Amazing progress, just caught up on the last 11 pages.......
I thought our subframe braces could be straight tubing, without bending it???
Mike
Reply #183
Quote from: mcb82gt;443925
If you were to put said braces on top of the frame, than that might work. We bent the subframe brace for the soul purpose of sliding one end of the subframe connector into the front frame for added solidity. Doing the same on the rear frame would be impossible unless you cut into the floor pans Sadly.
Either way, I'm just happy as long as the welds hold and my subframe connectors don't snap off. And, seeing as this is just a street car, I think they'll be just fine lol.
Reply #184
Quote from: jcassity;443921
Not trying to be mean, but i lol'd at that response.
Reply #185
I guess it could if you go under on the outside up front.
what surprised me the very most was daminc saying the front and rear are directly in line with each other.  Checked my 87 coug and 87 20th
, ,,, the rears are different separation than the front.
Reply #186
Quote from: Haystack;443944
yeah, imagine how I felt when you landed the question in my lap!
I went,, Ummm,, well..umm.....
Reply #187
started sanding down the Bondo on the trunk. It's gonna need some spots filled in with a second layer of Bondi  but it's coming together.
Also, the bottom of the passenger door is in rough shape  but we have a plan to fix that. So, it's all good.
Reply #188
short hair fiberglass on there now.. bondo comes later where needed.
Reply #189
Progress has been long awaited, we know. But, with the coming of spring and warm weather, the tools no longer freeze to our hands as we work. So, it's back to it with some k memeber modifications.
Ideas or opinions?
Reply #190
the first pic chance posted is to give more room for future rack / pinion access to fittings.
the last pic above is to open up clearances for exhaust and also future work on oil pan bolts / access.  there is some metal that can still come off to more or less make it look neater.
we should be making progress on a two piece oil pan soon, that's on our list as well so the motor doesn't have to come up to do an oil pan gasket.
Reply #191
Be sure that you put a K-Member brace like the ones MM makes on the rear of your modified stock unit as you took some of the strength out of the K-Member by removing all of that material.  Basically what you removed were large gussets that gave the k-member rigidity.
http://www.maximummotorsports.com/4-Point-K-Member-Brace-1982-93-Mustang-Hardtop-P810.aspx
It bolts in so easily removable when you need the access.  If you think the four point is going to be too restrictive then something like these two points would be a minimum.
http://www.maximummotorsports.com/Two-Point-Braces-C235.aspx
Darren
Reply #193
The trunk lid finally submitted to our ways.
Notice I basically omitted the sheet metal seam that is along the bottom edge filling with fiber glass.  ON the side you might be able to go back a few pages and see how I filled in the interior gutter with bead sealer.  that worked pretty good , came out thin then dried like a rubber band.
Reply #194
you may notice two big ass holes on the lower left and lower right that you don't have on your car.
that's for access to our spoiler hardware , for some reason we had to take off that much metal.
