Topic: Swapping faces (Read 1311 times) previous topic - next topic
Swapping faces
Hey guys,
I'm interested in swapping the aero face on my 87 to the 83-86 four eye face. I already have an 85 as a donor. Is this a straight forward procedure?
Thanks and happy thanksgiving!
1988 Mercury Cougar LS
5.0HO + T5 Swap + Suspension/Brake Mods
Swapping faces
The actual headlight wiring is different. I believe the switch and inside wiring is the same. I haven't done this myself, but i would assume you just splice the 4eyed headlights harness into your existing one.
A relay mod for the headlights will help your switch work longer. The headlights power runs through the ignition switch and headlights switch.
