Topic: key question (Read 1590 times) previous topic - next topic
key question
Why is the ignition key also the door key? Not just on Fox bodies either, MN12s are the same way.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
key question
How much of GM's bailout dollars went to making an extra key for every vehicle? :rollin:
key question
How many keys do you want to carry around?
At one point in time i had 7 fords from 78-91 all on the same key ring.
key question
I don't get this, most cars are like this.
If anything i would want all the locks on my car to use the same key, ignition, doors, and the trunk
key question
The reason for different keys was to keep parking lot jockeys from having access to your trunk and glove compartment. That's why the trunk release button is behind the glove compartment door on the 84.
