Topic: need help here cougar xr7 5.0 engine swap (Read 2515 times) previous topic - next topic
Im putting a 90k 5.0 out of my 1988 cougar into a 1987 that also has a 5.0 .the 88 has all anolog dash n heat.the 1987 is digital dash and electronic heat unit.anyways the issue im having is the engine harness out of the 87 looks a bit difforent then the.88.what will i have.to do to get this cat going.please help asap
Can i use the eec and harness from the 1988 without issues?the harness is in great shape
the 1988 harness ***IS***  a bit different, this is why there is a dedicated 1988 EVTM.
reference links to the 87 EVTM and the 88 EVTMs in my signature.
your 87 chassis has climate control  .......(answer questions below)
- does your 87 chassis have **FULL*** electronic instrument cluster or just a digital speedometer with buttstuffog temp and fuel?
this should get you started
The whole dash and heat unit is digital  all gauges are digital gas oil pressure volts everything is digi
You're looking to keep the digital dash, correct?
Yes i want to keep it digital.i would like the anolog but its alot of work and rewiring i heard so id like to just keep it as simple as i can on this project
