Topic: A couple quick questions (Read 1400 times) previous topic - next topic
I've noticed a light miss in my engine.  I've replaced plugs and wires, and cleaned the rotor out.  at idle the led guage will move one degree back and forth.  I can feel it as it does this, and at speed it's a little random vibration at times.  I'm unsure whether this is due to timing issue, or I'm getting some random arching.      The other possibility is dist positioning? Which on this vehicle I'm unsure how to do.
my other question is oil chime.  It happens semi-rarely, but will flash to the oil guage, and annoy me greatly.  This happens when I gun it over 70, and, some times when I turn from a stop.    Are these guages accurate in any manner? I know in other vehicles, the pressure sending unit was inaccurate and retarded; is this the case with the Thunder/Cougars as well?
Run codes.
A small strip of electrical tape takes car of annoying blinking lights...
 your not getting any top end noise, its likely just a worn out sender.
Dont take the chance put a mechanical gauge on it and read the Pressure. The miss normally wont set codes. Unless the SES light is on reading codes is not necessary. But try it .
If you get good pressure after checking with a mechanical gauge then your issue could be the sending unit or a voltage issue in that circuit.
