Topic: Not a Tbird or Cougar but.... (Read 1145 times) previous topic - next topic
 :ies:  :ies:  :ies:
now if I can just figure out where all these wires n connections go....very soon til my stang is on the road!! :ies:
Re: Not a Tbird or Cougar but....
ooh shiney. Looks like the engine is sitting too high though?
I don't know, haven't tried to install the hood yet :p shouldnt be tho, stock motor mounts and everything, I was told a 3/8" intake spacer would still clear the hood. I guess we'll see if I have to spend more money on a cowl hood
That shure looks nice! Refresh my memory, Is that a 306? I cant remember. It is coming along well...
1985.5 SVO
Eh you don't need a new hood... Just cut a hole and put a cardboard box over it! (ok j/k you can probably get a hood scoop/cowl off the older stangs and capri's and use that)
not a 306, just a 302. it was fresh enough to not need to be bored out.
and IIRC, motor mounts from the vert mustangs make the engine sit a little lower so if it is indeed too high I'll try those before gettin a new hood
mmm pretty.
Cobra manifolds rock! Good luck with the wiring. :D
