Topic: congealed radiator (Read 2979 times) previous topic - next topic
congealed radiator
I am looking  at a 83 3.8 that's beer  sitting  for a decade.  The inside  of the radiator  is rusted and congealed.  The car looks intact  aside from  the windshield.  The body looks straight  and rust free. Is it worth  $700 to purchase it?
congealed radiator
Yes and no. If thats what the radiator looks like, the engine is likely as bad or worse. When a car sits, rubber especially wears out. Bushings, seals, hoses ect are all toast.
If your planning on an emgine swap and basic upgrades, it would likely be a good candidate. You might get lucky and be able to reuse a bunch of stuff, but I wouldnt plan on it.
congealed radiator
What do you mean congealed? Do you mean the coolant has turned into something with a jello like consistency?
congealed radiator
My crownvic did the same thing when I bought it. I drove it almost a year before I popped the radiator cap. My waterpump failed and was leaking coolant. When I pulled the pump off, the water vanes were all rusted off, as were the nipples for the bypass hoses. It didnt overheat till it started leaking.
I tried to flush it out with a hose and even through bleach in it for a few days and it still would randomly overheat. Several months in a row I could drive it several hundred miles a week without any issue. Then every once in a while it would start blowing brown rusty coolant. Id top it off, and it was fine again.
I basically traded the crown vic for my cougar.
congealed radiator
Thanks  for the responses. Yes the antifreeze  turned jello like mixed  with rust.
I was honestly  thinking of passing on the car just based on the misleading  advertisp00get.  Although  on all used vehicles  I buy, I immediately  change rubber hoses and filters. The sheer expense to get this on the road even  as a back up car will be at minimum the asking price  of  it.
It is too bad the body, interior,  and frame look great.
congealed radiator
Is the "jello like" consistency a sign of a "stop leak" product being used sometime in the past?  I have never used them, so I don't honestly know.
congealed radiator
Could be stop leak/head gasket sealer, aren't those engines known for head gasket issues?
Swapped a radiator in my son in laws Silverado, it had stop leak in it and the radiator drain plug wouldnt even drain.  It was filled with some thick sludge black  that we eventually got through and drained and flushed the engine block.
Mike
congealed radiator
Quote from: BornInAFord;438754
Possibly. Depends on what product was used.
congealed radiator
Is there any ethanol in your fuel there? (I'm guessing there is)
If so, it's sat since the introduction of it, and I'll bet the fuel system/tank has rust issues inside somewhere...
