Topic: Some parts left - 87-88 headlights, 5 speed shifter trim, steering wheel, etc. (Read 3895 times) previous topic - next topic
I have a few parts left.
87-88 headlights - could use a polish. I also have the rest of the front lenses
5 speed shifter trim. In good shape. Both locating studs intact.
passenger side power seat track - like new
Chuck W motor mounts - need new bushings. If they don't sell I am going to clean, repaint and add new bushings and sell them for a lot more so make some offers.
digital dash cluster that worked perfect - here is a pic of it before car got parted out - a little dusty but lense is in good shape and everything worked.
removed
right side tail light in good shape
turbo coupe steering wheel and horn button in good shape
Make offers. I want this stuff gone.
1988 Thunderbird
5.0 HO, t5, TC rear, TC brakes, etc. - Gone
PM sent
I was going to ask how you wore out those mounts,.... then I saw out east with the rust.
Mike
pm sent
Go Fast the first time.  The tickets the same.
86 Thunderbird 5.0.  All original good weather driver. Tbird Reg #53035
86 Thunderbird TC.  All original good weather driver.  Tbird Reg # 58555
87 Thunderbird TC.  All original good weather daily driver.  Tbird Reg # 64647
Shifter trim and motor mounts sold. Make offers on the rest...
1988 Thunderbird
How did the bushings wear out on the motor mounts? Just curious - maybe I should buy more spares?
1988 Thunderbird Sport
According to Chuck(and his response was deleted) he changed suppliers of the urethane he used in the mounts. Anyone with an older set of Chuck mounts should check the urethane portion to make sure they are in good shape. Mine looked like dry rotted rubber on the upper portion. The lower portion was fine. The replacements he linked me to were less then 30 bucks so the fix is not expensive.
1988 Thunderbird
Cluster, motor mounts and shifter trim are sold. I still have headlights, steering wheel.
A few other parts I have:
Climate control - 100% functional when removed.
clock - also worked great when removed.
1988 Thunderbird
mounts came today, thanks again!!!
No problem!
1988 Thunderbird
Also have these:
They are for a standard car, not the TC front end:
Missing one stud on right side outer light. Was like that for years and I never noticed, and it held fine with the one stud left. It more then likely can be repaired with some hardware from Home Depot. Lenses are all intact, no cracks, in good shape.
1988 Thunderbird
Paypal sent for wheel.
Quote from: 88lx50;438852
How much fo' dis?
Would you consider selling me the headlights? You told me no before.
Please let me know. I have Paypal.
