Topic: What's the best rear shock absorber for 88TC? (Read 7264 times) previous topic - next topic
We have one rear shock that is leaking on the whiteBird 88 Turbo Coupe.
What shocks do most of you fellas recommend for these cars?
Ron
Speed is just a question of MONEY How fast can you go?    (M. M.)
It kind of depends on what your setting your car up for
Mines a DD but I wanted a firmer feel and my car is lowered so I went with foxbody mustang kyb gas a justs with chucks shock adapters
When I looked into this years ago, I found that Mustang people loved the general feel of the Bilstein HD units. The Koni yellows were quite stiff, and the reds a bit soft. Overall, the consensus was that the Bilsteins had great control, but they weren't rock-hard.
So I picked up the Bilstein HD struts and shocks. They feel excellent. Many years later and still good. I'm sure I'll have a time when I'll make use of the lifetime warranty. Having them and full tubular rear control arms really changed how the car handled. I can't imagine what it would be like going back and driving a stock suspension tbird or cougar.
1988 Thunderbird Sport
Thanks guys,
Since these TCs have the ride control switch, I wondered what might the best way to go when replacing them.
Is the ride control build into the shocks or can any shock be used and still be able to use the control switch?
Ron
Quote from: BLKBRD88;438382
Thanks guys,
Ron
You lose the firmness control. I don't believe there is any way to keep the adjustability these days - no rebuild options out there.
The ride control system is basically dead.
Another vote for the Bilstein HD's.  Couldn't be happier with them.
Ok guys thanks for the info and advice.
Not the best news, since I wanted to keep this car as stock as possible and I hate to lose the ride control, but if new parts or rebuilds are nonexistent then I will probably follow the Bilstein route.
Ron
mustang rear shocks require Chucks adapters or you can flip the stock mounts, but they are still a little too short.
Mike
Quote from: mcb82gt;438482
OK, who is Chuck, & where do I get his adaptors?
Since this is the car that my wife drives more than me, I don't want it to be too harsh, but I do want better control when we go on vacation and I drive. That is why I hoped to keep it stock with the ride control, so we would both be happy.
Ron
Chuck is a member on here, makes motor mounts and used to make the Mustang shock adapters.  I think he quit making them, but im not sure.
http://www.turbochuck.com/motormounts/
Mike
I had to post a wanted ad to get my adapters and I believe Chuck still hasn't had any for sale since
If you like the stock shock and the ones you have are leaking or something just put some used stocks back on
There's plenty of people here that just have them laying around including myself and wouldn't mind parting with them
Quote from: Ramos617;438590
……………….If you like the stock shock and the ones you have are leaking or something just put some used stocks back on
You have my undivided attention, how much for a good used pair shipped to:  86329?
Ron
Let me see what exactly I have back home
What are you looking for ?
Front struts, rear shocks, or a full set?
I believe I also have some quad shocks since I run tubular control arms out back
Hey Ramos,
Sorry it took so long to get back to you.
The left rear shock on our 88Turbo Coupe is leaking & needs to be replaced right away.
If the price is right I may buy both rears & have the other for future use.
Ron
Bumpity bump……….Ramos617 did you find out if you have the rear shock that I need?
Ron
