Topic: 1986 cluster speed always says 0 (Read 1236 times) previous topic - next topic
My cluster no longer has rpm which is fine wired up a tachometer but I kind need my speedo loll any idea why it wouldn't read I did swap from aod to T5 I see the vss is connected and in but is it possible to have it in and not have the gear spinning it?
The t-5 gears are slightly different. I know some gears wont mesh properly and have to be trimmed in order to fit in an aod.
 id inspect the vss. Take a drill and hook it up to the vss, and see ifnyou have any speedo movement. If you do, id try ordering a new speedo gear, might need to get both a driven gear and the drive gear for a proper reading.
Its faily simple to swap the driven gear, but youhave to remove the tailshaft and shifter, so id try just the drive gear on the vss first.
