Topic: Send TBird232ci to the CatJam... (Read 1248 times) previous topic - next topic
Selling off some more stuff i have laying around, or at least trying
i have a pair of tripminders, converted and ready to go for most 85-87 cars, and some 88's, asking 85 shipped each
i have a pair of WORKING electro-illuminecant cougar C-pillar embelums, asking 55 shipped
1987 stang computer, 5-speed, speed density, has an ADS superchip module on it, 75 bucks shipped
intake manifold assembly, upper, lower, and throttle body from an 87 TC, 50+ shipping
IHI turbo, no shaft play, no wastegate actuator, 85+ shipping
i have a bunch of other stuff, if you need something, PM me, if youre interested, but need to discuss price, PM me
Re: Send TBird232ci to the CatJam...
Quote from: Tbird232ci
I don't know much about the wiring on these. Some 88's? Also, blue or which shade of green?
1988 Thunderbird Sport
What he means is that on some 88 models the "fuel flow" wire in the factory harness will not be connected (it will be there, but not connected to the computer). I was lucky - mine was connected :D If you don't mind running a wire from the right kick panel area to the center of the dash you can easily make it work in an '88 that doesn't have it connected.
You can tell easily enough if the wire is "live" - plug the tripminder in and go for a drive. If your fuel economy is in the 100 MPG range it's not connected (the tripminder sees no fuel flow so it thinks you're getting impossible fuel mileage). Also, if you go to the "fuel used" mode it'll always report zero gallons used.
actually Carm, i mean that some 88's dont have the connector for the clock in the harness
it appears that most of our cars didnt got the fuel flow wire in the clock harness, the wire thats in the position of the fuel flow wire is actually the dimmer/illumination wire for the clock, buttstuffog and digital
the tripminders are the blue/gray when lit, but you can hardly even tell the difference, when i tested my TBird tripminder, and the crown vic ones, there wasnt much difference
bump
Do you know if the manifolds & TB would fit a '93 ranger 4-banger?  lookin at making my friend's truck a turbo ranger.
Black 1988 XR7 - HO Upper, TB, and Headers.  Dynomax Exhaust.  Looks like  from a bad hit, but its my baby!
im honestly not too sure because that has the dual plug head, which i know nothing about
