Topic: 86 cluster wiring diagram needed!!!!! (Read 3009 times) previous topic - next topic
Car is a 1986 ford thunderbird base model that came with a 3.8l v6 and has the all digital cluster.
I need a wiring diagram, or any info, regarding the 2 connectors that plug into the cluster.
I need to know which one of the wires is the "signal" wire from the fuel level sender so i can hook it up to my new gauges.
Also knowing which one is the speedometer "signal" wire would be a huge help.
Bonus questions:
What signal are our fuel level senders? is it 73-10 or 20-150 ohms?
Is the speed sensor a hall effect 3 wire or a sine wave 2 wire sender? pulse amount would be nice too.
Thanks everyone for any help!
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
Wiring info here (click on the cluster type):
http://www.coolcats.net/general/cluster.html
Our fuel level senders should be 73-10 Ohms.
I'm not sure about the speed sensor. I remember going through that when buying an aftermarket fuel gauge…something nags at me that it's the sine wave but not positive. Bought the fuel gauge, hooked it up, works fine. :)
86 evtm
Speed sensor is 2 wire sine sender (AC generator). Both fuel and temperature senders are approx. 100 - 10 Ohms (oil pressure sender for buttstuffog cluster too).
Hey guys, thanks so much for all the help! Installation was a snap! Prototype cluster went in great. Hopefully be able to optimize design and get it up on this site in the vendors section.
