Topic: Fox Mustang 5.0 accessory brackets (Read 1111 times) previous topic - next topic
Probably a long shot, but does anyone have all the brackets for a/c and power steering from a 5.0 stang? Preferably with all the bolts, but i can probably find some that work if necessary.
I tried to install my kenne bell blower today, and discovered that the thunderbird brackets are completely different than the fox stang, even though the accessories are in the same spots. Hopefully I can get a set of brackets relatively quickly, my car is down till I get them.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
I have them all from 89 5.0 stang with bolts-$75 shipped
John
Awesome, I can do that. PM sent.
87 Thunderbird 5.0
TC 3.73 L/S rear
