Topic: 93 cobra r wheels and tires ?? (Read 2051 times) previous topic - next topic
Will they work on my 87 cougar XR7? Thank you
More info needed.
93 Cobra or 93 Cobra R?
Real or knock off?
Std 93 Cobra 4-lug 17" wheels have too much offset for a Tbird/Cougar, and will pull the wheels in about 3/4" per side.  Not ideal.
REAL 93 Cobra R wheels are 5-lug, 17" wheels (the same as a 94-95 Mustang 17" wheel option) and won't bolt up without the obvious mods.
In easiest terms. If the wheels will fit a stock Fox Mustang, they will fit a stock TBird/Cougar.
Doesn't say just says cobra rims they are 4 lug, What are some specs for wheels to look for that will work? 4x108= I do not know the rest?
What is the off set that I can use etc...?
How about posting the link, or whatever, that you're looking at?
They were on Ebay now gone, I did find out they are 4x4.25(108) 5" BS, 17x8 front 17x9 rear or 17x8 all around, and like you said If it fits a 87-93 Mustang it will fit my 87 Cougar XR7.
So, knock-off 4-lug "Cobra" wheels.
