Topic: Rear deck cover (Read 4306 times) previous topic - next topic
Rear deck cover
I want to remove the rear deck to replace the carpet material. Will I have to remove the side interior trim by the quarter windows or no?. Also what are the speaker size in the back as I hope to replace those also.  Thanks.
 S O L D
Rear deck cover
I remove the rear seat and the rear c-pillar panels.
Rear deck cover
I was afraid of that.  lol.
 S O L D
Rear deck cover
Its two bolts on the floor, and I think 6 screws. No big deal.
Rear deck cover
The rear speakers are 6x8, but you have to get them from the bottom (in the trunk).
CoogarXR : 1985 Cougar XR-7
Rear deck cover
I am going to do this as well on mine before I store it away for winter - this is a great forum
Rear deck cover
Quote from: vinnietbird;436961
Quote from: ISTLCRUZ;436968
Quote from: vinnietbird;436969
Hopefully those two bolts on the floor aren't rusted.
If I need to remove the C-pillar trim, I usually loosen the back half of the A-pillar trim as well as loosen the upper rear window trim. Pulling the front seat belts through the C-pillar trim slots allows you to move those pieces of trim out of the way if you don't want them hanging there. If you need to take them off for your project, might as well remove the C-pillar emblems and clean up the paint on the outside and put a fresh coat of wax there and remove any old wax residue from around the emblem.
I've only ever removed that deck carpet once and too long ago to remember if I had to pull the C-pillar trim.  I don't remember having to remove that trim but this was back in the 90s. Long time ago. I also remember some sort of thin formed layer of foam attached to the deck carpet. Is there a formed under side of foam attached to that carpet? Can the carpet be easily separated and replaced without messing up the foam?
Rear deck cover
All my seats are out and at a shop to be recovered. I thought now was the time to tackle this rear deck project. Yes it dos have some type of padding glued to it.
 S O L D
Rear deck cover
I have a really good original one in the dark charcoal color. $50 +shipping. I am guessing that would be around $25 to you. This one came from an 88 TC that was apparently kept out of the sun. Not faded.
 XXX
Rear deck cover
Well, I finished it. Found some speaker box carpet on Ebay the right color and it worked pretty good. Pretty simple job and well worth it. After I trimmed it to fit I used spray glue and then let it dry over night and popped it back in. While I was at it I replaced the 3rd brake light bulbs and the round light bulbs as well. Thought this may save me time down the road.
 S O L D
