Topic: Broken Ball Joint at 40 mph (Read 3006 times) previous topic - next topic
So my 1988 Thunderbird Sport broke a ball joint  the other night doing 40mph , the car come to a grinding stop had to have it towed home. Took it apart and the ball joint was broke in half and the lower control arm is chewed up. My Question is will 94-98 mustang lower control arms work and can I just replace one side. thanks
X
[ATTACH]34701[/ATTACH
I've got '99 Stang control arms under the front of mine. I think the ones you have will work fine, and yes, one will work fine. I can't remember if you need to install the Thunderbird style ball joint or if the ones in those control arms will work. Glad to see the car is o.k. and repairs are actually minimal.
Quote from: vinnietbird;436738
I havnt bought any control arms yet, hoping I can get one that the ball joint will work with my car maybe someone will know if the mustang ball joint will work?
The 94+ arms will work, but if you have Fox spindles on there, you will need Fox ball joints.
Quote from: Chuck W;436752
The car is completely stock,  could it have fox spindles being stock? So if it is stock and not fox the control arms and ball joint 94+ mustang will work?
If it's stock it has the Fox spindles. These are fox chassis cars. 94-04 Mustangs are SN95 chassis - very closely related to the Fox, but slightly different. You'd need an Fox ball joint in an SN95 LCA. Unless you're upgrading the front suspension or the Fox control arm is unavailable I wouldn't bother with the Mustang one...
So my problem is there are no junkyard around with any thunderbird/cougar parts. So when calling them what other control arms should I be asking for? iam looking for a direct bolt in part, on a tight budget.
87-88 Tbird/Cougar control arms are a bolt in, in regards to length and ball joint type. 83-86 TBird control arms are NOT the same.
94-04 Mustang arms are the same length as the 87-88 arms, but have the SN-95 ball joint.
Other option: Buy a new ball joint, rent a ball-joint press tool, install in current arm on the car.
OR change them out. I have i think some TC A arms in my trailer. This is why a car should be inspected at 6 month intervils. Or at least once a year. The joints most likely were in need of replacing quite some time ago. better check the other side for wear. have a great day guys
What are the symptoms of failing BJ?  Im getting a click/pop from passenger side front when touching the brakes, I cant duplcate it rocking the car up and down???
Mike
I know when I've had fox body ball joint issues, the car squeaks like a honeymoon mattress going down the road.
CoogarXR : 1985 Cougar XR-7
