Topic: 88 v8 tbird issues (Read 2403 times) previous topic - next topic
88 v8 tbird issues
I got a 5.0 tbird that ive had for 12 yrs car has been good to me except for the past yr I bought my black TC so I really wasnt worried about it but now TC is giving me problems so I just want to get my baby fixed about a yr ago I was driving the car everyday to work then one day the car just decided it was going to stall every time I slow down to a stop and hesitation bad when u get off throttle and get back on throttle its like it stalls then all the sudden it just kicks n
I have changed about every sensor that I could think of I changed the ignition switch and car got better but still does same thing Ive run a code test and I got same codes that I always got before when car was running good any suggestions would help I got lots of time n this car she is my baby thinking about getting rid of my TC just to much headache
88 v8 tbird issues
Post the codes you are receiving.
Mike
88 v8 tbird issues
mabe the TFI is going
88 v8 tbird issues
symptoms of
fuel pump putting out low volume
fuel injectors clogged up
fuel filter clogged up
weak spark (check this at night with a spare spark plug from any cylinder plug wire with the threads of the plug bonded to chassis ground)
~~spark needs to be blueish white,,, anything else is weak spark which points to the dizzy TFI or the pick up module down inside.
pull your codes with a paper clip and if you have one, a 12v buzzer.
88 v8 tbird issues
Well I haven't run codes on car yet I have a few months ago but I don't remember them I can tell u that car runs good with hammer down but it is eye burning rich and idles funny sometimes up and down sometimes it sounds like popping threw exhaust
kind off erratic. This has been replaced since I have on it. Idle air sens TPS fuel pump and pressure regulator ATC and temp sens fuel filter I think I need to replace egr sens
88 v8 tbird issues
You really need to pull the codes and post them. My knowledge is limited on the TC's but if there is a mass air meter (cannot remember if the 87-88 cars had this or not) try cleaning the MAF elements.  If there is a MAF and you do not know how to clean the elements post back up.
Darren
88 v8 tbird issues
id pull the iac and clean it or see if it needs to be replaced. does it want to stall sitting at idle and suddenly turning on the ac or turning the wheel?
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
88 v8 tbird issues
Thanks for replies. My TC I had cleaned the maf didn't make much difference I have codes posted on another thread and my 88 tbird sport
I have replaced IAC and yes it does sometimes stalls while idling my biggest problem is major hesitation when give it throttle u get off and get on its like engine just shut off then it just comes n hard I've changed a lot of parts on this car I have ran codes and one was egr and it does work but if u hook up vacuum sometimes  car acts stupid figure that is probably one problems
