Topic: Intake, MAFs, throttle body for sale (Read 1040 times) previous topic - next topic
It's time to get these extra parts to a new home. I do accept pay pal. Prices include shipping and are OBO.
Explorer GT40 intake:
Internal EGR style. No cracks in the upper or stripped holes. Lower has the ACT hole drilled. Who ever did it buggered it up a bit. I screwed in an ACT sensor, closed off the runner, and filled it with water and it didn't leak. It should be air tight. Includes bolts. $150 shipped
Edelbrock/BBK 65mm Throttle Body and spacer:
Ran this on my Thunderbird before switching to a 70mm TB. Clean. $150 shipped.
C&L 73mm MAF:
Has the gold calibration tube for 94-95 Mustang GT with 19lb injectors or 94-95 Mustang Cobra with 24lb injectors. $55 shipped.
70m MAF with F2VF sensor:
Ran this on my Thunderbird with 19lb injectors. It has a F2VF MAF from a 94-95 Mustang GT in the 70mm housing from a 94 Thunderbird Super Coupe. The only difference from the Mustang housing is that the Super Coupe housing doesn't have a  so it works with the stock Mustang intake tubing and air box. Replacement for the 55mm MAF used with the A9L/A9P Mustang MAF computers. $45 shipped
70mm F2VF MAF:
MAF from a 1994-1995 Mustang GT. $45 shipped.
stock Mustang MAF air tube, SOLD
C&L air tube $65 shipped
5.0 heater pipe SOLD!
For this part: stock Mustang MAF air tube, $35 shipped, there should also be a rubber piece that goes on the other side of the maf.  Do you have that as well?
T-Birds can't fly.  Ask how I know...
Quote from: Lodemia;435670
I do not. However you can pick up a 3" plumbing coupler at the hardware store that will work just the same.
No one wants to make there car go fast? :hick:
One more thing.  how big of a maf and throttlebody can you use with the stock air tube?  I have a 70MM tb and 73MM MAF.
Quote from: Lodemia;435941
I have run a 70mm TB and 73mm MAF with the stock air tube no problem.
Bumpity
