Topic: Cup Holders (Read 3806 times) previous topic - next topic
Cup Holders
the Kia Sportage has a "pop out" cup holder that is built into the center dash area.
push it in, the dual drink holder pops out.
push it in all the way and it stays closed.
holds a can, or a large fast food drink.
many people dont have an available bay in thier center dash area to add this,, i certainly dont.
people with a storage up there may make good use of this idea.
the reason i like these is that they are simple and only require about 3/4'' height clearance / space occupation inside the center dash area
see examples of what i am speaking to.............
they are very inexpensive and at this time should be widely available
http://www.ebay.com/sch/eBay-Motors-/6000/i.html?_nkw=kia+sportage+cup+holder
ebay ^
i honestly can not say there is **NOT** any other solution for our cars.
Cup Holders
oooooh, put that kia cup holder thing like above the radio? Cuz I do have an empty spot there. I only have a radio and climate control unit. I like that idea.....A Lot
Cup Holders
Quote from: kylesburrell;435410
hmmmm, i hadnt thought of that! Now Can you keep the ashtray door? That way when you need a cup holder you can open it, but when you dont need it, just keep the lid shut.
But my car is column shift. So I was thinking of putting 2 cup holders in front of the climate control unit.
No because the space necessary takes up the entire ashtray area plus a bit more, unfortunately there's no way possible to leave the door on it.
