Topic: Temperature Gauge (Read 4360 times) previous topic - next topic
Temperature Gauge
Just wondering here. I havent driven the car in temps above 75ish yet and the temp gauge is always at the middle or a little below, never beyond the "O". Yesterday it was about 85 and I had the A/C on the entire time. Nothing unusual on the highway or streets but when I stopped somewhere and the car was idling for about 10 minutes it went on top of the "R" and was touching the "M", and even after a burst on the highway it barely went any lower. The car sat for a few hours, then on the way home it was a little over the middle but not as high as earlier.
I know my Mark VII would normally be a touch over the middle, but does this sound unusual considering where it runs in not much cooler weather?
Thanks.
1986 Thunderbird 5.0
-FRPP Wires and upgraded ignition parts.
-H.O. Upper Plenum / EGR Spacer / TB
Temperature Gauge
The same thing happened to me yesterday. On the way home from a car show it was pretty hot so I had the AC on and noticed that the gauge was above the center of the normal range but it didn't go any higher. I shut off the AC to see if it made any difference but no change. Everything seems to be O.K. so I guess that is just the way the cooling system works.
Temperature Gauge
Maybe the IVR playing tricks.....Instrument Voltage Regulator....
I wouldnt worry too much....if you know your cooling system is healthy.
Travis
Temperature Gauge
That is strange. As far as I know my cooling system is in good shape. It didn't go beyond the M and last week I drove about 65-70 miles round trip with only 1 or 2 30 minute stops with no A/C on(I didn't recharge it yet) in hot weather and the temp. gauge was normal. It must be how it goes with the A/C on? It still wouldn't go past the "M" but it still threw me off.
I've read the back and forth here and elsewhere, any real downside to throwing in a 180 deg. thermostat?
Also, are the 9 blade Mustang fans a direct swap?
Thanks.
Temperature Gauge
Quote from: ThunderFox;434868
Thanks.
I've got a digital gauge in mine. It lights up three bars for about 1-2 miles driving in any condition then lights up four bars after that. Doesn't matter if it's 50* or 95* with the A/C on. It stays at four bars (half way up the gauge) all the time. I had it go to five bars once when I was running the original radiator and idling in traffic with the A/C on high and the outside temp was 100*.
As far as the 180* thermostat and the 9 blade HO fan yes they are a direct swap. I run both of them along with a Police Interceptor fan clutch. The engine runs between 180*-190* according to an infrared thermometer.
Temperature Gauge
Quote from: thunderjet302;434872
Cool, sounds like my situation is normal for hot weather and AC blasting. I think I'll pick up the Mustang fan and 180* T-stat and see how that helps.
I have to deal with a new problem that just popped up at lunch today. I went out to go to the store and the car immediately was running like . Rough idle, sputtering on acceleration, almost stalling and for some reason it sounds louder. The car ran great on the way to work. So weird...
Temperature Gauge
A 180° thermostat changes the dwel time the coolant sees in the radiator. anything below 180 will also make the car run rich and kill gas mileage.
if all is well, a 192 is more then adaquate. my 87 bird did well with stock 250ish k mileson the water pump and a cheap single row radiator with ac on all summer till the timing chain cover gasket let coolant out. never got above m unless the guage was acting up.
Temperature Gauge
I'll give the Mustang fan a try first before the T-Stat since it's easy. But i have to have a new cat and y pipe put on since thats why the car was runnng so horribly yesterday. Its definitely an exhaust leak and i dont think its the manifolds. Those pipes look like  so it has to be that. It wanted to stall at every light and was popping and sputtering. I knew it was on borrowed time but i didnt think a leak there would affect drivability so much.
Temperature Gauge
We'll I'm an idiot. Took it to a shop just to check the exhaust, all good. Then I ran codes, MAP sensor. Checked it out and the vacuum hose sprung a leak.
PIA bc I don't want to take the manifold off again. Is there usually a clamp on the MAP hose under the intake? What size and length is the MAP hose if anyone knows off hand?
Thanks.
Temperature Gauge
I use a pen housing and electrical tape as a side of the road fix.
More likely then not your motor mounts are shot allowing the engine to rock causing the hose to fail.
Temperature Gauge
Quote from: Haystack;434914
Or he cheaped out and didn't replace the MAP hose ;).
Temperature Gauge
Hey, my pen roadside fix from two years ago was still on the car. i didn't even own it then. i patched it up when my buddy fixed the car.
Motor mounts seem to be made of paper for me for some reason.
Temperature Gauge
Quote from: ThunderFox;434877
A 180 degree thermostat will only delay overheating if you have cooling issues. A thermostat fully opens at 15-20 degrees above what it's rated for. At 195-200, a 180 degree t-tstat if flowing the same as a 195 degree t-stat at 210-215 degrees. If you have underlying issues and get stuck in nasty stop-n-go traffic in a hot day, the 180 degree stat will only buy you a few minutes before it's running just as hot as a 195.
Temperature Gauge
Quote from: JeremyB;435132
That's all I'm looking for. AFAIK the cooling system is working properly, the radiator looks to be in good shape, there are no leaks(other than my ignorance in excluding a hose clamp from the bypass hose) and the coolant that I drained for the T-Stat install was a nice clean light green. I'm just looking for more cushion when the A/C is running full blast on a hot day. I'm going to upgrade to a heavy duty fan clutch and the 9 blade Mustang fan.
My Mark VII was in great shape and the Temp. gauge would stay a little over the middle(just not as far) on hot A/C days ad that car had no issues idling with the A/C on for hours. It still gets me paranoid though. Lol
Temperature Gauge
The mark came with a thicker radiator.  3 core brass as opposed to 2 core.  I run a 3 core, 9 blade fan, SSP fan clutch, and a 180° t-stat.  With my setup, the stock stuff, I would imagine I'd overheat rather quickly on a 90°+ day.
