Topic: 1988 thunder bird turbo coupe (Read 3321 times) previous topic - next topic
any one have pics for under the drivers side dash i removed a black box with with 9 pin wires need a picture of it
Can you take a pic of the box and post it so we can see?
Donnie
10 Second NA TBird
Fredericksburg Va
XXXi will do that ty
i need the color codes on the wire
Pretty sure that is connected to the cruise control.
Quote from: 50RACER;434584
Pretty sure that is connected to the cruise control.[/QUOTE
Its been a long time since I've seen one of those, but I believe you are correct.
Donnie
10 Second NA TBird
Fredericksburg Va
thats the seat belt, warning chime moduel..
If you could post a picture that clearly shows the Ford part number that would help immensely.
Darren
the part # is e7db-10d840-aa
Quote from: tonyboy;434638
Zenith was correct. I just googled the part number and it comes up as the seat belt warning chime module.
Donnie
10 Second NA TBird
Fredericksburg Va
Quote from: 87 T-BIRD;434639
idid the same it fits f150 in the 90s
will my seat belt lock still our it wont work
Quote from: tonyboy;434640
It supposedly also fits a few other vehicles. I know from working on Fords over the years they would use the same part on several different models covering several years.
Donnie
10 Second NA TBird
Fredericksburg Va
Quote from: tonyboy;434641
Yes your seat belt will still lock, you just wont have a warning light on the instrument cluster. The seat belt locking mechanism is built into the belt ratchet asy behind the B-pillar where the shoulder harness goes.
Donnie
10 Second NA TBird
Fredericksburg Va
