Topic: Parting out 1988 Thunderbird LX (Read 6793 times) previous topic - next topic
Quote from: Tbird-fanatic;436741
Pics of the the door panels please. Trying to figure out if they are the style Im looking for. The TC ones just dont hold up over time for some reason
I will get you a pic of the door panel. It has the TC style panels, but the insert is not cloth. The panels are not so great, but the arm rests are in good shape, as well as the map pockets.
1988 Thunderbird
5.0 HO, t5, TC rear, TC brakes, etc. - Gone
Vinnie - how does 45 shipped sound on that trim piece for the shifter? I will get you a pic. The boot is still attached and in decent shape.
v8Demon - seats are shot. I have some good body parts that you might want. Passenger door is good. Both pieces of door glass are good.
I also have a set of Kenny Brown subframe connectors with seat supports that are pictured earlier in this thread that I can make you a good deal on if you pick up.
1988 Thunderbird
Bodyman - how is 60 shipped, including a high volume walbro pump?
1988 Thunderbird
Sounds good, pm paypal info and I will get you paid. Thanks - Joe
Quote from: bodyman;436750
Joe - I am back at work on Tuesday. Let me drop the tank, and get you a pic, and then you can send payment. It worked fine and was accurate, but just want to you to see what you are buying first.
1988 Thunderbird
I have those same connectors already.  They're awesome.  Full console car or consolette?
Quote from: V8Demon;436755
It was a consollette car originally, but I cut it off and added a full console.
1988 Thunderbird
Never mind on the door panels then, If I have to go thru dyeing and such I want the other style. I know the panels I'm looking for were the same ones my old 88 sport had.
Joe - I sent you a pic of the sender
1988 Thunderbird
Reply #39
Vinnie - a few pics of the shifter plate. It is in nice shape.
1988 Thunderbird
Reply #40
PM sent :)
Reply #41
Interested in subframes, you still have them?
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Reply #42
Still have the subframe connectors. Sent you a pm.
1988 Thunderbird
Reply #44
I have them but the plastic covers are shot. The buckles and webbing are in good shape.
1988 Thunderbird
