Topic: Out of Guts (Read 1074 times) previous topic - next topic
Out of Guts
I have a 351w swapped into my 84 Bird. The problem that i am having is that when it is ran hard for awhile, it will develop a miss during1/4 mile acceleration. It acts like it is running out of gas, but i dont know why it would only do it when it was hot though. Maybe the coil is failing when it is really hot.  Any help will be appreciated, thanks, robert.
Re: Out of Guts
A hot engine is more pr0ne to detonation.  Maybe you should try knocking a coupe degrees off the timing?
Re: Out of Guts
could also be the fuel pump starting to go. Check your gas pressure.
