Topic: Question about rouge wire.... (Read 1442 times) previous topic - next topic
I'm wrapping up a GT-40 intake swap on my '88 Sport.
There is one wire that I am a little confused on where it goes. Its a single wire with a connector on the end that runs along the drivers side fuel injector loom and down the front of the engine behind the power steering pump. It came un-plugged while I was moving the wiring harness around and I can't seem to figure out where it goes.
I'll be able to take a picture of it in the light tomorrow but I was just curious if anyone knew where it went...
1988 Thunderbird Sport aka 'The Beater Bomb!'- Eibach Sportline Springs, Removed Silencer, Straight Pipe Exhaust
3G Alternator, Mustang 8.8", Thunderbird Sport 10" drums, 3.27 gears on a locker.
Oil sending unit by the filter?
oil sender is white red
low oil sensor is dark blue/light green
coolant temp sender is red/white
there is an unused single wire but two port connector near / within the hvac harness.  this connector is very flat and about 3/16'' thick and about 5/8'' wide.
double check all the vast amount of connectors along / downstream of the ignition coil and along the battery.
Probably the oil pressure sender wire. If not it could be for the low oil level sender, if equipped.
Yeah I got it, It was the sending unit wire. Thanks guys!
