Topic: chin spoiler option 28$ (Read 1818 times) previous topic - next topic
found this at a bone yard that is brand new.  The bone yard ordered it for someone who did not come and pick up.
aftermarket cost for this item is 28$.\
you will recieve an item that is way too long for your application, just cut off each and and design your own look.
we used spare hardware i had , you can do what you want.
this thing with little or no mods simply bolts down to the face of your existing air scoop.
pn and install pics.................
Very cool!  Might have to do this myself.  Think it would work good on a LX front bumber?
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Not bad, not bad at all. Shape the ends a bit to give it a finished look. I like the Mach 1 style. It can be had for less than $60. I know it costs a bit more, but I sure like it.
Quote from: GDawg148;433749
i dong see why not,
the nuts will still pass through the bumper itself due to the similar design.
we were reaching down inside the nose to add the nuts.
Do you think it could be tucked behind the lip on the bottom of the bumper? Might gain a bit of ground clearance.
we didnt try that but that would make it sit at an even more lower profile.
the nomenclature for this item is called>
"lower valance",, forgot to mention that if anyone tries to buy it and search for the right item.
its a sub-assembly of the front bumper
