Topic: Fuel lines needed for a V-8 car.... (Read 1530 times) previous topic - next topic
I need the two short fuel lines that go from the metal lines abobe the rear end to the fuel pump hanger. Let me know what you have.
up....
what year
'88 cougar 331 supercharged build in progress
'95 Blazer solid axle swapped 4X4- daily driver
Vinnie.  Do you mean the nylon fuel lines?  If so, you can check out my thread here for what I did:
http://www.foxtbirdcougarforums.com/showthread.php?37393-Fuel-Tank-amp-Fuel-Line-Replacement
The 18" replacements will work, you just need to take your time with the caulk gun, and take your time hanging the tank so you don't end up with what my bird had when I got it :dunce:
Geoff
T-Birds can't fly.  Ask how I know...
Thanks a lot. I am going to try to find the stock Ford replacements first. If I can't find the piece, then I'll give that a shot. I do appreciate the info as the part numbers will be of help.
Quote from: supercharged88;433110
what year
1988, 5.0
No problem.  Good luck.
For what it's worth, it looked like the lines from a Taurus of the same era would work, but I didn't want to waste money on stuff that might fit.  I was able to find a taurus stuff easier than t-bird stuff for some reason.
Quote from: vinnietbird;433011
How fast do you need the lines? I will be removing the factory fuel system and putting a fuel cell and braided lines in the Bird as I redo everything.
Donnie
10 Second NA TBird
Fredericksburg Va
I'm in no big hurry. I can wait a while with no worries.
Quote from: vinnietbird;433142
Ok, I will let you know when I start taking things apart.
Donnie
10 Second NA TBird
Fredericksburg Va
That will be great. Thanks a lot and I appreciate that.
