Topic: Proportioning valve. (Read 1249 times) previous topic - next topic
I have a 88 tbird LX 5.0. Front disc, rear drum (mustang 8.8). Noticed the front plug in the proportioning valve leaking. Not getting a whole lot of stopping power from the rear so I'm getting nervous. If anyone has anything let me know. Thanks guys!!!
My rear brakes were 5% stopping power of the front, passed saftey fine. id try fixing the leak.
The car was stopping much better before 2 days ago. Might end up getting an adjustable wildwood valve
Bumpskiiiiii
I have one from an 88 turbo Coupe. Don't know if that would work with what you have.
No. I think they are different.
Yea that turbo coupe prop valve will give the rear brakes too much stopping power
Find one the same as yours or use an adjustable prop valve.
I'm doing my brakes right now and I'm using a wilwood adjustable valve, it's a nice piece, your probably going to need some adaptor fittings to get it into your current lines but it's worth it.
Any idea if a fox mustang prop valve will work???
Stenholm
I have an 88LX that im parting out, you pay shipping and the prop valve is yours.
Justin
