Topic: Mercury Turbo Coupe wagon........kind of..... (Read 1635 times) previous topic - next topic
Awesome!! Although, I'd swap the center horn button for one with a cat on it ;-)
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
It's interesting that he swapped the 83/84 style dash, but kept the marquis cluster. I didn't think they would interchange physically (I always thought the marquis cluster was slightly shorter, guess not). The marquis cluster doesn't have any oil, temp, or turn signal indicators either (those are on a bulb strip above the cluster). Interesting.
CoogarXR : 1985 Cougar XR-7
I want that car. I'd swap in a newer dash though.
That is pretty cool other than the cheesy exhaust and T-bird horn pad.  I'd rock it!
Oh man this would make the perfect sleeper
Neat swap....but needs front mount IC and supporting mods....probably run 15 flat and get 25mpg...
Travis
