Topic: Draining gas tank (Read 1917 times) previous topic - next topic
Draining gas tank
I m trying to find an old post about jumping two wires in the diagnostic port to run the fuel pump so i can drain the old gas out.cant seem to find it can some one help me out with the post or the terminals
Draining gas tank
Its in the sti self test port... i don't know which one, but it needs to be grounded if i recall correctly.
you can also find the green relay in the trunk area and jump it there, but i beleive you need computer input to trip power to the relay.
Draining gas tank
Just ground the fuel pump wire in the diagram below.
Draining gas tank
Why not just turn the switch on?
...and there was light!
Draining gas tank
Quote from: T-BirdX3;432701
If your fuel pump runs continuously with the key on and the engine not running, you have a problem.
It means your ECU is in LOS (Limited Output Strategy) mode.
Draining gas tank
Thanks loaded87iroc that was just what I was looking for. Now i can drain the 2 year old fuel out and get the the cat purring again
Draining gas tank
Quote from: phyxius;432839
chassis ground the tan / light green wire within the diagnotic connector.
turn the key forward
the fuel pump will run continuious.
so with your fuel line separated (supply side which is the one with the shrader valve test fitting), and doing the above, you should be able to empty the tank.
normally the fuel pump runs for about 1 or 2 seconds by simply turnking the key forward then times out by way of the EEC noticing there is no ignition.
softtouch is right if or ever you notice this happening and usually its only root cause is someone has jumpered out the fuel pump relay in the trunk incorrectly and screwed up the eec.
