Topic: Fuel filler neck grommet... (Read 4029 times) previous topic - next topic
Is the Stang piece the same or do I need a different part. If somebody has a link or part number, I'd appreciate that.
Are you talking about the rubber at the tank where the filler neck slides in? If so I used a mustang one
I just put a new one in mine I ordered it from latemodelrestoration and yes it was the one for a stang
87 TC
Order one for a 94-04
Don't remember the part number, but it was for the same as a Stang.
Mike
I just used this one and it fit perfectly.
http://www.amazon.com/gp/product/B00BMEUUJ4/
Good Luck -
Geoff
T-Birds can't fly.  Ask how I know...
I ordered one for the '04 Mustang. I have a bit less than half a tank of gas, so, I'll burn a bit more before I install it. LOL.
Hit it with a bit of oil before installing. It'll help the filler slide better.
Thanks. I'll spray a little WD-40 on it when it gets here.
I got the one for the Stang as we mentioned above. It was too small. may have been the wrong part that i received. SO, I went to Autozone and they had one on the shelf. $27.00 and good to go.
I used a mustang one. Now I'm wondering if thats the source of the occasional gas smell
I'm sure mine was. Not now.
Quote from: thewestie;433026
Check your canister purge and charcoal canister lines.
My buddy at Ford told me to use a very light coat of dish soap to get the filler neck in.  Not sure why but it has worked well over the years.  I used one for a Fox Mustang on my '83.
Darren
Quote from: V8Demon;433062
Thanks
I don't have one of those any more. I kept the line as vent.
 I was told SCCA tech wants tank vented in front car.
 I'm wondering if I'm getting vapor smell from the braider lines.
