Topic: 2.3 Turbo Issues. (Read 1812 times) previous topic - next topic
2.3 Turbo Issues.
So I've felt like my engine has been horribly down on power lately. It's an automatic so the boost only tops off at about 7 lbs but it has horribly slow free revs that take close to 6 to 7 seconds to go all the way up to red-line. Also I tried doing a 0-60 to see where it'd be, it took 14 seconds. Lastly it idles between 500 and 700 rpm. It doesn't feel like it use to and my dad could verify that, what could be wrong??
2.3 Turbo Issues.
1. Run Codes
2. Check fuel pressure (the small hose in the tank cracking with age is common, it will run, but like )
CoogarXR : 1985 Cougar XR-7
2.3 Turbo Issues.
Thank you!
Also I'm getting horrible gas mileage! Something like 13 to 15 mpg
2.3 Turbo Issues.
Honestly, that is very vague and so hard to troubleshoot.  Could be the timing belt has jumped at tooth or two.  As suggested could be fuel related.  Vacuum line could be corroded or broken.  God only knows.  Check it out and let us know.
Mike
2.3 Turbo Issues.
Distributor could have loosened up and lost some timing too.  Should be 10* with the spout out.  If it makes you feel any better, my 2.3T/C3auto cougar only gets 15-16mpg
2.3 Turbo Issues.
My last fill up i Got 9.9 miles to the gallon. I know I drive on the more aggressive side but 10 sounds nothing like what its best was, about 30 according to my dad.
2.3 Turbo Issues.
Usually with low fuel pressure they will go into a continued bog when the boost comes up...
Even with boost up to 12.5psi my white bird with A4LD would get 17-18 in town, and 25+ on the highway... The 5-speeds were about same in town, but could push 30 on the highway...
2.3 Turbo Issues.
Ok....to the original poster you need to create a signature so your fellow website brothers can help you???
So many things can be wrong on a 25+ year old car.
The 2.3 is pretty easy but we need help to help you.
Also http://www.turbotbird.com is abit better at this then this website.
Good luck
Travis
2.3 Turbo Issues.
The linkage rod to the waste gate??? Had it happen once to me.  Man was the car a slow poke with NO boost.
Love Foxes, Birds or Stangs.
