Topic: strut tower brace that fits 83-88 cougs & birds (Read 3880 times) previous topic - next topic
need to know what source / pn to order for a birthday gift for my son
need pn of the strut tower brace that spans the engine bay or if there is one available.
just lost my job a couple weeks ago, hope this $ doesnt hurt too bad
Try BlueOval Industries....They  offered them at one time for like 1oo bucks.
 S O L D
no dice there either...  i thought for sure i had seen members on here with this on thier engine bays.
may have to just make one
Shouldn't one for any fox body stang work? If so maybe check a Mustang site like Late Model Restoration? Im pretty sure Vinnie has a strut tower brace on his Sport as well. Maybe Vinnie can chime in here. Good luck with the search though.
 S O L D
Any mustang one should work, but you may have to drill a hole or two out for it, and the winsheild hose squirter is in the way of the tri brace style.
i assumed the stang ones were too short due to narrower chassis, assumed the strut towers were closer together as well,, will likely order a stang one then,, those seem available.
http://www.coolcats.net/modifying/frame.html
firewall forwards is basically identicle. there are minor differances in suspension and wheel base, but most parts for a mustang will physically bolt in place.
never even thought about checking out eric's page,, thanks!
Make sure one for a Fox stang is ordered, the SN95 cars had a different firewall/cowl and the bars for them will NOT work, or at least the 6 or 7 I have seen haven't.
I've got one for mine...Maximum Motorsports, I believe.
Lou, (thunderjet302) has a bar, though I don't recall the brand.
Stacker is correct, you'll need to relocate your washer fluid hose, other than that, direct bolt-in.
I used a Maximum Motorsports strut tower bar. It went in with one mod to the passenger side strut tower mount. It did hit my hood insulation but that's because my car has a thicker aftermarket hood insulation pad. Link here:http://www.foxtbirdcougarforums.com/showthread.php?33889-Maximum-Motorsports-strut-tower-bar-hits-hood&highlight=strut+tower
Maximum Motorsports. Please realize that there is one for injection and one for a carbureted setup like the '85 Mustang GT. Give them a shout as they have dealt with this before on the T- Birds.
This is a shameless pig but give my buddy John George a shout at http://www.chicane23.com as he can usually get you a better deal than buying direct from MM. Chicane is a MM dealer so it's on the up and up.
Darren
Quote from: Aerocoupe;432689
Darren
I used the fuel injection one. Make sure you get that one if you have a 5.0 with SEFI. The carb one will work for the CFI 5.0 cars.
sorry guys, i pulled the trigger before reading the posts above.
i got Item # 16196 from american muscle.
looks to be from user pics for FI 5.0 fox mustang chassis.
ah yes, MM , looked at them again.
couldnt tell from anyones pics how the fire wall connections were made.  i imagined in a collision the two bars getting shoved into the firewall penetrating things.
the MM looks like it has the strut tower metal connection plate i wanted.. the one i just ordered does not have that much meat.  I could weld on to suffice this adder on the item i just ordered.  oh well..
ships to me sometime next week.. may have time to fit test it to my 20th and have it ready for my son's bday when he's here around the 15th of may.
Quote from: jcassity;433197
There are two pinch welds on the firewall where the cowl and firewall meet. from the factory there are also two holes in these pinch welds. The MM bar actually bolts to those pinch welds. Other strut tower bars require you to drill holes into the cowl. The MM bar has a much more rigid mounting point than the strut tower bars that have you drill through the cowl.
As for the strut bar getting pushed into the passenger compartment in an accident: if you're in an impact hard enough to push the strut towers back then you've got bigger problems than the strut bar moving ;).
