Topic: Front Drag Racing Springs (Read 909 times) previous topic - next topic
Here is a link to the springs. http://www.jegs.com/i/Moroso/710/47220/10002/-1&parentProductId=747983
These are new, never installed, Moroso Trick Front Springs.  These are for a foxbody and are super tall springs.  You will need to cut them to fit! (Even if you have a mustang they would still be cut to fit)
Part #47220-100
Spring Position:Front
Spring Type:Coil
Minimum Front-End Weight (lbs):1,630 lbs.
Maximum Front-End Weight (lbs):1,700 lbs.
Spring Rate (lbs/in):250 lbs./in.
Asking $80 shipped.  I accept pay-pal.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
