Topic: Hard gas pedal on first start...? (Read 2569 times) previous topic - next topic
I have been having an issue with my gas pedal being very hard to push down on first start, even sometimes when driving. I tried cleaning the throttle body plate with throttle cleaner, thinking it may be getting "hung up", but that didn't help. Any suggestions or other causes ?
Thanks in advance :bowdown:
http://www.coolcats.net/help/pedal.html
If its hard to press, then frees up for the remainder of travel likely the blade is sticking in throttle bore... You'd check that with throttle and kickdown cables removed then see if it sticks when fully closed, if so it'll need a tweak to base idle which will probably mean resetting TPS voltage...
Just replace the throttle cable. you'll be amazed at the differance.
I tried cleaning the plate or blade inside the throttle body but it didn't help. Also sprayed the area with wd-40 where the throttle cable can be manually accelerated under the hood (the black button looking thing) and still didn't help. Probably need a new cable.
Could also be the kickdown linkage. everytime i fire the tbird up (t-5) to move it i can't beleive how much looser the gas pedal feels.
Is that something that can be sprayed ?
It goes from the transmission to the throttle body. May need a bit of lube at the points that move. Make sure nothing is binding.
Also check the cruise control/speed control cable that connects to the throttle cable. They can stick and cause binding.
