Topic: Digital Speedometer Light is out! (Read 10857 times) previous topic - next topic
Hey guys, the light behind my digital speedometer burned out.  Can anyone tell me if this is a bulb I can just go pick up at AZ or AAP?  Part number? Any info if possible.  I know nothing about the electronics.
My panel light (door light) in between the two overhead map lights is also burned out, any info I can get to help me replace this bulb would be much appreciated! Thanks!
X
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
I don't know the number right off, but it's a basic bulb.  The number is in the owner's manual if you have one.  The whole cluster has to be partially removed to get to the bulb.  There are several threads with tips about this.
not sure of the actual #, but 194's work, it takes 2 and they're at the top, behind the odometer.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
X2. I put in a 194 equivilent, and now speedo is super bright
i actually had to drop my steering colum to get the cluster out, so be prepared for an hour or so
I agree the 194 bulb will work...The last time I had a cluster out I changed all the bulbs while I had it out. Thought it might save me doing it again later. There are ALOT of bulbs  in the entire cluster.
 S O L D
Hey! I think i just had the same problem. The numbers in the speedo shows, but are too dim? Well, that was the problem with mine. I thought it was a bulb, but no. What i did was taking out the whole dash, disconnecting all the electric cabels and put it together again and then it worked as new! I dont think you get normal bulbs to just the speedo, so probably a bad connection somewhere.. maybe? i dont know much about this stuff and had a lot of help.
http://www.coolcats.net/help/dash.html
I had this happen after I installed a radio and I never did figure out the cause but I'm not afraid of wiring (but it's afraid of me) and after a bit of testing I just supplied my own power to the speedo light.  I take my cluster out somewhat often (don't ask) and I don't drop the column.  Usually some maneuvering and tilting the wheel is all it takes.
This mystifies me. my guage cluster had a bolt mounting point already broken from someone trying to force it out. i didn't remeber dropping the colum on any of my other cars, but i tried for 10 minutes or so till i gave in and dropped the colum.
I didn't want to start a new thread for the same problem. I was adjusting my TPS with the ignition on and came back to the drivers seat to see the speedo light out only and there was a slight burning smell while driving it before this occurred.
Are #194 bulbs really an exact fit for the digital speedometer light?
Thanks.
1986 Thunderbird 5.0
-FRPP Wires and upgraded ignition parts.
-H.O. Upper Plenum / EGR Spacer / TB
There should be 2 #2033 tiny halogen bulbs and 6 #194 standard bulbs in the standard cluster according to user's guide or instrument ilumination. This means, those #2033 have to be inside the speedometer. They have orange color coded socket.
User guide also says "Replace with Ford Part Number D2OB-18C622-AB or equivalent, if available (Bulb is an integral part of assembly)"
If they are still too bright, you can use #161 or #37 light bulb.
Before you put a bunch of time into the cluster, be sure to check for a melted ignition switch connector.  I had this with my full digital a couple years ago, and that's how it turned out.
to part b of your question, T37 for the thumbwheel dimmer panel within the lower left of the IP controls.
t37 also shows up in many plugs on the full digital cluster
T194's typical within the whole standard and buttstuffog cluster.
T37 bulb for your radio incase you can no longer see the channel your on
while out i recommend doing the heat sync mod to the high temp resistor on the back of the cluster as it will eventually melt your flex print harness.
(this is in my diy link below). All you need is a piece of soap stone about 2'' long.
Cool down that big resistor on the back of your buttstuffog instrument cluster.
This also applies to those with digital clusters except the resistor is smaller.
http://www.foxtbirdcougarforums.com/showthread.php?34327-buttstuffog-cluster-*solve-that-heat-problem*-on-the-big-3-long-reisistor&daysprune=100
You mean remove that stupid heating nonsense, am I right? :)
That thing is TOTALLY USELESS. I throwed them away from both my birds and everything work fine.
BTW, daytime lighting is mandatory in our country, so you can imagine, how the flexible board feels like while driving in hot summer. I guess, there is a quite big risk of fire because of that.
Quote from: jcassity;433269
The nice thing about the no-clock radios, is that the display is only on when the radio is on. The ones w/ a clock are on whenever the key is in On or Acc, or the lights are on.
Quote from: Trinom;433270
You know there is a way to wire the headlights up so they function as DRL's, and only the headlights will come on, anytime the car is on. That way you will have your running lights without having to use every other light on the car at the same time...
If you want, I could help walk you through the process....
