Topic: Newbie with a wheel question.....what fits? (Read 1565 times) previous topic - next topic
Hi there!
I'm brand new to the forum, and have a clean 1988 T-bird Sport with 74k original miles.  One of the first thing I plan to do is change the wheels and tires.
I'll definitely go with a 4 lug Mustang/Cobra wheel, but I want to be sure they'll fit before I buy.  I've narrowed it down to the gunmetal 17x8 Cobra R or gunmetal 17x9 10th Anniversary Cobra wheel.
The 17x8 Cobra R's have a 5.09" backspace and +15mm offset, while the 17x9 10th Anniversary wheels have a 5.79" backspace and +20mm offset.
I just want to be able to bolt the wheels on and go.  The car is in excellent shape, so I don't want to modify it if I don't need to.
Thanks in advance.
Pose
No idea on the offsets, but our cars shared rims with the mustang. I'm running 10 hole gt rims. i put some 275/60's out back. i like the way they look, but it barely scrubbs with all my tools in the trunk. I'm going to try some 275/50's next time, or maybe something in 255 size.
17x8 will fit up front.  17x9 you will probably need spacers in the front.  Rear wouldn't be a big issue fit wise unless you have quad shocks.  (the ones that go horizontal)  This is just suggestions from what I've researched and to help you get a idea of what to search for.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
Sounds good.  Thanks for the pointers.
Also I think 87/88 front control arms different than 83-86.  Make sure you keep that in mind.  Not sure how but I am 99 percent sure.
Quote from: custompunk;431629
87-88 Thunderbird/Cougar control arms are the same dimensionally as 94-04 Mustang control arms. 83-86 Thunderbird/Cougar control arms are the same dimensionally as 79-93 Mustangs.
