Topic: Dash cluster cover plate (Read 1297 times) previous topic - next topic
Anyone have luck getting rid of haze on the supposed-to-be-clear cover plate that goes in front of the dash cluster?  I used a mildly abrasive wax on mine yesterday and it laughed at me.  I'm debating on picking up a headlight lens cleaning kit and giving it a shot.  This plastic seems softer though so I'm leery.
I have never tried this on the plastic so this is not a recommendation.  This is just how I clean headlights.  Buffing wheel, rubbing compound.  It will scratch it/clean it.  Then a coat of clear coat over it.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
Meguiars Plastic X worked pretty good on mine. You could also try their Ultimate Compound followed by Plastic X. That has worked well for me on clear plastic before.
x-2. I had a nearly white lens that I was able to rescue using the plastic X.
ok.  I'll give it a shot.  ;)
